I've stumbled across this item on eBay and am thinking about buying it, it's cheap.
I can't see the Manufacturer on here, so I am cautious. 0
Has anyone bought modules from Hampshire electronics and would recommend them ?.
https://www.ebay.co.uk/itm/Dual-Buffered-Multiple-Synth-Module-4HP-Eurorack-Hampshire-Electronics/303924457022?trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160727114228%26meid%3De722e9b1a9f24012b259337b37722efc%26pid%3D100290%26rk%3D1%26rkt%3D4%26sd%3D303924457022%26itm%3D303924457022%26pmt%3D1%26noa%3D1%26pg%3D2060778&trksid=p2060778.c100290.m3507
or if you have any other recommendations for Buffered multiples, please share them ?.
Good and solid :
https://www.modulargrid.net/e/erica-synths-black-8-multi-v2
Less expensive, good and solid :
https://www.modulargrid.net/e/doepfer-a-180-3
doepfer - a little bit more expensive but built like a tank - there will be people with ones that are over 20 years old still going strong
mutable instruments links - about 3 times the price but not only do you get 2 buffered mults and a mixer, one of the mults can also be used as a pecision adder and a mixer - very very useful module
or just take a gamble on this one - it's 30quid! do you have anything to check it with?
Thanks, I think I'll go with either the Doepfer or MI.
Hi Slammer22,
The Erica Synths - Black 8 Multi is so far the best buffered multiple I have. Being "the best" as in comfortable to use and from a patching point of view. The bad news is that it's sold out :-( I only got one of it and wanted to buy a few more but then I was already too late. I checked this with Erica Synths but it's really sold out :-(
The Black 8 Multi is so logical to use and it has four outputs per input channel, no other modules (with 4 HP width) can do that, as far as I know, in such logical and comfortable way.
Indeed the Doepfer A-180-3 is another good choice.
Other option might be the ACL - Multi II that exists of two parts, a buffered multiple and a passive multiple, 6 HP, so it's comfortable to use while patching.
Good luck in searching for a good buffered multiple and kind regards, Garfield.
Thanks Garfield.
I've bought the MI Links, was a decent price.
@ GarfieldModular
For the Erica Synths - Black 8 Multi, maybe you can find it in Greece :
https://www.synthesizer.gr/Erica-Synths/erica-synths-black-8-multi-v2
and at Thomann (the link don't work) :
Search "Erica Synths Black Multi"
Hi Jihel,
Thanks a lot for your reply. The shop in Greece indeed still sells them but at what price...? Wow!
The Thomann one the "Black Multi" that's the successor of the "Black 8 Multi" (Erica Synths told me). The Black Multi has only 3 outputs instead of 4, it has an octave/offset switch per multiple instead. I rather had the Black 8 Multi, the perfect (dual) buffered multiple...
I need to give the Greece shop a thought, thank you very much! Kind regards, Garfield.
Hi Garfield - I just checked the synthesizer.gr link and they seem 'reasonable', how much were they before?
Hi Jim,
The only one 8 Multi I have, I bought that one for Euro 42.35 (including VAT) and guess from whom?
From Erica Synths' their website-shop. If I knew at that time that it was such a good offer and that they were going to be sold out and that it is such a good multiple, I would straight away have bought some more...
Dealers had the opportunity to buy at a reduced price this and other modules from Erica Synths as well, hence my reaction that the price is far too high. Kind regards, Garfield.
Hi Garfield
I see why you were shocked then!
Jim
